[SOLD] New Small Block Purple Shaft Cam P4120657
68383S
Charleston SC
*****SOLD*******
Brand:Mopar Performance
Manufacturer's Part Number:P4120657
Part Type:Camshaft and Lifter Kits
Product Line:Mopar Performance Purple Camshaft Kits
Summit Racing Part Number:DCC-4120657
Cam Style:Mechanical flat tappet
Basic Operating RPM Range:4,000-7,500
Intake Duration at 050 inch Lift:265
Exhaust Duration at 050 inch Lift:265
Duration at 050 inch Lift:265 int./265 exh.
Advertised Intake Duration:312
Advertised Exhaust Duration:312
Advertised Duration:312 int./312 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.590 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.590 in.
Valve Lift with Factory Rocker Arm Ratio:0.590 int./0.590 exh.
Lobe Separation (degrees):106
Intake Valve Lash:0.028 in.
Exhaust Valve Lash:0.032 in.
Computer-Controlled Compatible:No
Lifters Included:Yes
Lifter Style:Mechanical flat tappet
Valve Springs Included:No
Retainers Included:No
Locks Included:No
Valve Stem Seals Included:No
Timing Chain and Gears Included:No
Assembly Lubricant Included:No
Pushrods Included:No
Rocker Arms Included:No
Gaskets Included:No
Valve Springs Required:Yes
Quantity:Sold as a kit.
This is new in the box, just been setting on the shelf for a while
$120 Shipped
Thanks
Small block/Big block?
Clean, no surface rust?
Can we get a shot of the actual cam?
Pay-Pal OK?
It should be stated, no?
(I'm thinking about it though.)
I guess I know the MP camshaft part numbers by heart....lol
Thats too funny.. Ive got the same came unopened sitting in my garage... Not looking to hijack ...dont worry...
