The hole will be welded this wek-end.
When I bought the 72 Swinger. The guy gave me a 1970 B body 8 3/4 and these springs. Could it be that the springs are for a B-body? Are B-body springs shorter than A-body?
A guy at my local parts shop, suggested that I make a couple of spacer blocks and install in back of the shackle bracket.
So, how do I tell if these are SS springs?
Also, is there a left and right?
Ok, here's an update. As you can see in the first photo (above), the shackles were almost horizontal. I hooked a come-along to the shackles and hooked it to one of the tow rings, on the front of my truck. I had the rear end hanging. Now the shackles are almost perpendicular. But I can't pull them any further because it starts to pull the whole rig.
Also, what would the ride be like with the shackles the way they are?
Any ideas?
Thanks
