New Upper Rad Hose
barracudadave67
Burlington, Wi.
Has any one got an idea of what P/N or mod yr of vehicle I need to get one from, for my new aluminun radiator, ??, the upper out let is on the pass side, going to an LD-340 Eddy Manifold, on a new 340. I'ts a new "Northern" aluminun rad.
The stock rad had the out let on the driver side, and I don't think I'll be able to just walk in a parts store an get one as easy as the stock one.
I prefer a smooth molded rubber hose and not the convoluted type, for better flow.
Just wondering what you guys that have put in new aluminun rads, have used on the upper hose. The lower hose is on the same side as the stock rad.
Thanks, Dave C.
Good luck finding a hose. I've a post on a part # for one but so far no luck. I have seen two molded hoses in pictures but haven't found the right one yet. If I find one I'll let you know.
I'LL do the same for you Valiant 72. I htink I'm going to try and go thru the hose stock at our local auto parts stores here. Bend a coat hanger as to how it should fit and go from there.
Thanks Dave C.
