Newer 904 trans for 65 Barracuda with 273
Bill Athas
New Member
Boyton Beach, FL
I want to replace the original 904 trans with a newer non cable version and use a B&M or Hurst shifter. The drive shaft has been converted to a slip yoke. Which years would work?
Thanks
you may have to have a custom convertor built with a smaller pilot to fit into the lil' engine....not sure if a 66 tranny has the small pilot or not...hopefully someone on here will know.......
Thanks
dammit i lost the page but 65 was the last year before the new 66 cnanges to 904 tranny try to google 904 chrysler trans or chrysler 904 trans mission repair its a gr8 old teachers vidio from chrysler they used to teach there mechanics or techs wish i was closer i would take yours off your hands i put a B and M cable on mine you have to get the kit that mounts to your tranny thru them also but hope you find the vidio very interesting if i find it again i will pm you look for olman rick , cracked back , fishy , tony aar cuda or go to tranny tech and post it you"ll get a very good tranny man to help you
I recomend that you will get your crankshaft machined for the newer trans. 67-> has the biggger hump on the converter. I have a lock-up trans from 89 behind my 273 and its good.:D
Thanks
x2.
You have to machine the crank for the 67 up trans. In my 63 Dart I have a 65 273 and a 76 904. The crank is machined to fit the converter. In my garage a B&M shifter waiting to mounted in the 66 up console. The rear end is a 69 8 3/4. And yes, I know it's a crazy mix of parts and model years.
x2.
62 Valiant, 66 front end with 71 disc brakes, chevy custom power brake booster, 64 273 with 71 318 heads, 89 904 lock-up with B&M Star shifter, 71 8 3/4 rear end converted with disc brakes from Toyota Avensis and Pegout 307 calipers. Crazy mix of parts?:D
