dodgegtdart68
I am looking for ANY & ALL information on this tachometer. How to wire it in ??
I don't know but be careful lest you ruin it. There are several possibilities...........
May have a battery hidden inside needs replaced
May need an external sender like the older Suns
(If this is the case try hooking your ohmeter to it and swap lead polarity both ways, look for any meter movement of the tach)
May hook to coil + (and ground)
May be set up to trigger on mag/ alternator pulses on a 2 stroke such as outboard
That is one reason I'm thinking it needs a senderIt does have a screw so u can turn it 4 / 6 / 8 on it. The black wire is a light and there's only the red wire.
The sender is a brain box similar to the old time tachometers, Sun tachs & others used them in the later 50's up until the three wire tachs came in the market.
Tachs such as the old Sun that need a sender, the "head" just a delicate meter (milliammeter). There is no electronic circuitry in the head. The head has two wires (from the meter) that goes to the sender.So how would it hook up ??? What do u meen a sender ???
Ok thank you. So what should I be looking for to make this work ????
