Nite Moves
I have a 73 318. I need a nipple from the intake that sits under the thermostat housing. Anyone know the size i need? Can you get these anywhere? Thanks.
Thank you.........wasnt possitive on the size. Nor where to get them.3/4" pipe fitting for the 1" by-pass hose...mopar performance has them part number P4876374 google "340 by pass hose fitting" theres tons of sources to get them. Summit Racing, Mancini Racing......
I just went to the plumbing dept at CT,used a piece with threads on both sides.You,d never know as both sides are covered.Cheap and readily available.
Did someone say Nipple??
