Maybe someone on here knows something about these things/ has experience with repair.
We bought new maybe 3 years ago tops. Have never done anything to it like thawing it out and we keep things clean.
Last few days the freezer started weeping on the floor. My wife cranked it all the way up last night, still food thawing.
I removed evaporator cover and find the evap completely iced over almost.
I am hoping that we can let it sit overnight, thaw it out and be done with it but Im guessing its not quite that easy.
Its a Frigidaire Model PLFU1778ES7 if that helps, side by side, the other side is regular refrig.
Just going on-line I can see ( assuming I am understanding things correctly ) that this is not supposed to freeze over, something is supposed to come on a few times a day and thaw these coils out?
Thanks for any suggestions.
EDIT: if the freezer evaporator coils ice over, the freezer does not get cold enough. Several times a day the defrost heater assembly turns on for a few minutes to melt away any frost or ice that may have accumulated on the freezer evaporator coils. If the defrost heater assembly has burned out, the frost will build up on the coils and eventually no air will be able to travel through the coils to provide cooling to the freezer. The most common cause for this condition is a problem with the defrost system............
So where is the defrost heater?
