But I would have to re-calibrate my photo-chromatic proton generator to achieve that.
It's ethier a recalibration, correct for the increased flow or you could go old school with a mechanical rotating finnigan pin through the whatchamacallit in the round houseing that will accept the square peg block inverted through injection rib. (Girls have an extra rib, just a FYI.):read2:
With this set up, the square peg acts like a regulator with stop action, (also good for claymation movies, but thats another topioc and can be found in the video section) It very similar to a stobe light when highly stoned, but, since it's a mechanical item and foot/rpm regulated, the amount of overflow is limited.:read2:
You'll need to run a heavy duty spring downstream (under the square peg) of the flow so as the flow increases, the spring is depressed and more flow will enter the matter stream. Much like a mechanical secondary & powervalve all in one, the Finnigan pin set up was excellent for it's day and can still hold on toe to toe with some of the most updated systems out there. It just can't match the mileage and emissions of todays devices and so hence was discontinued.:sign10:
But how cares! We don't need no stinkin smog tests!:cheers:
them old school guys sure knew how to make it work. I just find it amazing that the square peg lives at 800,000 RPM's, extreme pressure while regulating the strobe esentricks of the matter stream without distrubing extreme flow or creating poor feed back and waves
and doesn't brake apart.:toothy10:
The one thing I love about this system is even though it's a mecanical system, it doesn't have the harsh vibrations to disturb the newer system like the photo-chromatic proton generator can get from a bad road, ruff engine, poorly balanced engine, loud music, ruff sex in the car induced by chain rattling or blunt object strikes, extreme hauntings from ghosts, poltergeist or even worse, nagging mother in-laws/girl freinds, being rammed by deer, badgers, 3 headed dogs, the spirt of st. Louis, It's also shock proof against Hurricanes, Typhoons, NorEasters, earth quakes up to a 7 *I beileve it is* not to sure, Tree and telephone pole strikes except direct hit from them and lighting and planes larger than the SPirt of St. Louis, Piper club OK, Lears under 300 mph OK if it's sunny but not cloudy or less than 80% sun.
It's also good against paint fade, road grime and tar, but not from cig's or cigars, reffer OK's by the FDA & AAA as well as the back room NASCAR guys, NRA only with guns in the same room but OK to be load in the next room
Also OKing the system is the queen of England, Mel Brooks, Tom Hanks, Lt. Dan, Sgt. Slaughter, Tom Arnold, Rosane, Bruce willis (Die Hard saga) and his buddy Ashton K, Shirlie Temple as well as Mr. Ed. Lassie and flipper, etc....:sign10:
