Hey guys and gals just for the record I have used the search option on the forum and haven't got anywhere so I'm looking to the members for help. My dad and I have been working on his 70 swinger to get ready for a local show in September. We were going to fire off the fresh engin today but ran into an oil problem. We have tried everything we can think of prior to pulling the engine back out. The engine is full of oil there are no leaks, we hooked a oil pressure gauge right to the back of the block and are not getting any readings on the gauge. We have tried priming it with a 1/2 corded drill and are coming up with nothing. We checked the plug at the distributor bushing & it's there, we checked the plug in the block at the oil filter & it's there. We have enough pressure after priming it that it will squirt out when loosening the oil filter. We also tried turning over he engine while priming with no luck. We're not worried about cam break in because the cam is a used one that came out of my motor when I went through my 360 last year. Just trying to rule things out before we pull the motor. Any thoughts?
