Hi Folks
Stupid me.......When assembling the dash and steering column, I confirmed that I had no electrical gremlins before the install. I checked the hazard light output at the firewall block. Unfortunately, the rear light feed comes out of the dash to the body block.....Which I neglected to test.
So, continuity testing between the hazard feed and the 4 output wires (switch activated and the hazard flasher jumped) shows continuity to the front sockets and nothing to the rear.
Am I replacing the signal switch assembly, or has anyone had any luck getting this thing to work. I believe that the hazard switch is faulty.........
Thanks FABO
Thanks FABO
