MR4V
Building a era 70s Dart Swinger as you can see I think it's pretty close.
Picked up a correct date code 360, I was told it was stock but when I pulled it down I was supprised to find. J heads with 2.02 inlet, 1.60 exhaust, standard rockers, double value springs.
Block has standard bore, zero deck, forged pistons, ARP rod & main bolts, standard crack, balanced & HV oil pump.
Now the engine will take a hone, rings & bearings, heads will need a reco.
What I'm after is a nostalgic cam, inlet, carbie & sump combo. I was told that Dodge dealers use to fit Offy inlet manifolds, Carter carbie & soild cams as a after market offer is this correct?
My combo so far is 3.70 diff, tricked 904 with no stally as I have not choosen a cam, tyres will be 26" to 28".
Can anyone help me with a nostalgic or period correct combo?
