Capt46
I would have purchased mirrored stainless and had the fronts cut on a laser for the face rectangle shape and then use 3m double faced tape for the application. GRRRRRRRRR
Well I understand that the front surround does look good and primarily that along with the inside edge above the lens is all that you see through the bumper. However, on two of the bezels they didn't even smooth out or fix the inside edge above the lens. You can see that in the finished pics I posted. At the minimum for what I paid I want everything you see from the back of the car to look good. Here is the before pics I sent to them before they started the job.
...At the minimum for what I paid I want everything you see from the back of the car to look good....
Plating won`t cover crap, they should have been repaired before being chromed. Plain to seeWheeew I am ready to have my bumpers done on my 66 and was considering Paul’s being somewhat local to N.Y. I think I will definitely passssssssssssssss on that thought.
That's how I did mine and I got rid of most of the pits I ended up painting the backs and inside of buckets with an Alloy Rust inhibitor paint which came up pretty good . Chrome edges on mine were pretty good to start off with. Little while back there was a really good set on Ebay for a 66 Dart with good lens and the Vendor was only asking $130.00.Those would have smoothed out pretty good with bead blasting, IMO and probably looked a LOT better.
Find how they prepped them.
Thanks everyone for all your opinions and advise. Yeah I sent a message back to Paul’s Chrome with detailed pics and an explanation of why I was displeased. I did speak with them before sending detailed pics of what they were starting with. They knew what they were working on before getting the bezels. What I was really surprised by, is that the areas that are visible from the back of the car when mounted, weren’t finished properly. There is about 1/4 to 1/2 inch of depth above where the lens sits. Three of the four bezels had pitting and scaling on those areas. See pics attached. They didn’t even fill, sand or prep those areas correct to make it right. I know they weren’t the best to start with but if I knew they were going to just disassemble the wiring strip them and dunk them in chrome I would of reconsidered for $200.00 to $250.00 dollars apiece. I don’t think I’m being unrealistic and many of you are validating that. I do realize that for them to sand, fill and smooth the entire bezel not seen, might be overreaching, but I would of prepared the bases myself. Other than the chroming process I could of done a much better job myself. I’m still shocked!
Carl
If you had sent them to Leanna, she would have cleaned them up, coated them with something like Alien silver and you wouldda been happy.....for a LOT less. She can still fix them up, I bet.
@CudaChick1968
... Here is the before pics I sent to them before they started the job.
View attachment 1715122918 ...
