Well all of that sounds good and it looks like it should. Nice installation, BTW!
Did you get air from both MC chambers when bench bleeding? You should have. And was this done on the bench or in the truck? The concern with the rod adjustment is that the pistons are able to slide all the way back to the stop when the brakes are released. Was the rod adjustment into the MC done by measuring? Since you can't see it when assembled, that is the only reliable way to do it that I can think of. If it is too long, then the pistons won't go all the way back.
BTW, if you press on the brakes really hard with the truck not running, do you get a hard pedal with the pedal not too far down?
BTW, do you know WHICH GM calipers that you have or the piston diameter? If you got the smaller one, which have 2.38" diameter pistons, then that is smaller than the Mopar ones, and will reduce front brake torque for a given pedal pressure. They will put about 18% less pressure on the pads than the stock A body Mopar calipers with their 2.6" pistons.
Knowing the rear brake drum diameter and shoe width would help too to get some idea if the front pistons are too small.
OK, well the 'metric' calipers have the smaller piston size. So that may be what is going on: with a given line pressure, there is less braking torque on the front than on the rear. This is reason that the rear brake size has been asked.... to see if there is a mismatch.
The rear brake torque has to do with the drum diameter, the shoe width, and the bore size of the rear wheel cylinders and the shoe materia. The front brake torque has to do with the rotor diameter, the caliper piston size and number, and the pad material. Without good data on all of these, it is kinda hard to call. So any more data you can provide is of help.
Try cleaning the front pads and rotors again just to make sure it is not something silly. I'd pull the front pads to see if they have been contaminated with anything.
If it is just too small a front brake torque the options generally are:
- put in calipers with bigger pistons (earlier GM ones)
- put in smaller rear wheel cylinders if they are available
- change material front and/or rear (Probably easiest on the fronts, like EBC Yellowstuff compound)
- put in a rear prop valve..... but it almost sounds like the F to R mismatch may be great enough to not just depend on that; I'd rather figure up where the bias generally is right now, and get it close with changes and then use a prop valve to fine tune it in
BTW MBM lists their PN PV2C as a GM prop valve but it may just be a brake failure switch and distribution block.
BTW#2 do the rears have manual or auto adjusters inside?
Here's a number off brake pad if it helps
1MD 154-7070A FF NTA
Caliper piston measures 2 3/8"
It means I don't know exactly all the parts that are inside that so-called prop valve.... LOL It DOES have a brake failure switch, that goes off if there is a leak on one half of the system. But, I don't know if it really have a rear prop valve; the 'thing' on the back where the rear line connects may be it but that looks odd for a prop valve; the 'thing' looks more like a residual pressure valve.....but I really don't know on this one."BTW MBM lists their PN PV2C as a GM prop valve but it may just be a brake failure switch and distribution block" Not sure what this means?
Well, what we don't know here is the size of the rear drums. Dana 60 truck axles can have some pretty big rear brakes. It could very easily be far more rear brake than the fronts. It would be good to go over any setup or installation problems you can think of.. it sounds like the OP feels he has things bled and cleaned up right but we aren't there to check directly. That always makes internet advice just that: advice.Of all of those suggestions, only using calipers with larger pistons or changing the pads will improve the braking on the front. Changing the rear wheel cylinders will reduce the rear braking, but it will do nothing for the front. Same for the prop valve. It will reduce the pressure to the rear brakes, but that doesn't increase the pressure to the front.
Brakes are very sensitive to the length of the pushrod, a small discrepancy there can make a big difference in the pedal travel and pressure generated. And even the small piston Metric calipers should be more than enough to hold the truck. The rear brakes locking up before the fronts is normal in a system without a prop valve (or a custom system where you need an adjustment), the rear shoes are held a very short distance from the drums and the way they're applied causes the shoes to grab faster, which is one of the reasons disk/drum cars come with prop valves to begin with. Plus with it being a truck and light in the tail end you'll need a lot of front/rear bias to keep from locking the rears up first anyway. But, like I said, that doesn't account for the front disks being inadequate, just for the rears locking up.
Also if trying to power brake the truck wants to push. Need improved front brake calipers and rotors or line lock?
My back brakes are locking up before the fronts I noticed as well, so I ordered a proportioning valve for more adjustability
This all makes sense because 11" front discs and 12" or 13" rear drums that are 2" or more wide is VERY likely waaaay off balance. This is likely the issue: The rear brakes are so strong that the OP has to let up pedal pressure to get the rear wheels to spin, but at that lower pedal pressure, the front brake torque is too low to hold. If things are way off balance, my preference is to better equalize the F & R brake torques before fine tuning with a prop valve.
Of course not.....you have more in front than in back. But the OP has it reversed with more bake than normal in the back vs. the front sizing. If you need a prop valve with your setup, with the fronts enlarged more than normal, and still lock up the rears slightly, imagine what 11" rotors and even bigger rear brakes will do to further push the bias to the rear.Maybe. I run 13" front rotors and 11"x2.5" rear drums with the stock '74 disk/drum prop valve on my Duster. There's no crazy imbalance.
