Mopar92
Ok. The V8 swap and trans swap is done. We are ready to start it tomorrow. I wanted to try to be safe and make the clutch safety work. I like it when stuff works as it should anyway. OCD I guess. Anyway, I put on the 4 speed two prong. Reverse light work as they should. I simply just cut the yellow wire and left it in place at the plug. Now, up at the relay... that same yellow and brown wire is hit with a test light. Hmmm. Anyway, I ran a wire from the clutch safety switch to that terminal and the starter bumps with the clutch as it should. The only reason I’m questioning this is that the wire for the auto trans is 12v hot. The wire from the clutch obviously is not. And it all works. What am I missing? I used this diagram for reference. It all works it just doesn’t make sense that the factory auto trans wire is hot and the clutch SS is not yet it works.
