kittypancake
I was reading a thread somewhere about a /6 with a late model OD trans. Now I can't find it. Any ideas what tranny this is and what it takes to hook up?
I suspect an adapter for the push-button shifter would be hard because I vaguely recall that the shift pattern is different, i.e. as the cable pushes out, the order isn't today's standard of P-R-N-D-2-1. I just adjusted the cable in my 64 a few weeks ago, but didn't think to check that. I was just focused on getting the valve body pawls to match the shifter (while I had the pan off). If true, then 65+ cars must use a different valve body. and my two 1965's (904 & 727) must be 1-year only since cable-shift w/ the modern pattern.you would have to build an adapter for the push buttons, or come up with something for a shifter.
