DrCharles
I had found somewhere a pair of 15" steel (rally) rims cheap, that had been widened to 10" with an 8" backspacing. Perfect fit for a B-body rear under my '72 Swinger with minitubs and 3" spring relocation, even though they don't quite match my OEM fronts.
But when I had Moser true the housing (it was bent a lot from the look of the rewelded ends) and the perches relocated, I also had them narrow it to stock A-body width, about 1/2" on each side I think. Anyway, the 8" backspacing is now too much. Tires are 295/50 and are really close to the frame rail on the left (rubbed on bumps with my saggy springs), a bit more clearance on the right but still close.
The quarters had been replaced before I got the car and the fender lips have not been rolled. (I would like to run 325/50 but that looks too tight unless I roll the lips). For now I want to center the 295's in the well so when I burn them up I can get sticky 325's on.
Anyhow. I'll do some more measuring but something around 7 or 7.25" BS will work. Any recommendations on a source for OEM-appearing steelies with custom backspacing?
I found this place for $175 each, no extra charge for custom BS. And they're in KS so not as expensive to ship to MO. WHEELS!!
Other thoughts?
Other thoughts?
