oem steel wheel 15x8 5 on 4 bolt pattern wheel info needed..
Never made. Aftermarket only.
What kind of car are you building? What modifications have been done to the rear suspension and wheelhouses?
didn't think they made them thought I would ask thanks
Don't know anything about your fabrication skills, but since you're planning to build a gasser style Dart I assume you have some. About a hundred years or so ago, I built a pair of 15 X 8 reverse chrome wheels with the small bolt circle. I did it simply because there was no such thing at the time, and I wanted to run 15" 60 series tires. The year was 1971, the vehicle was a, then, brand new 340 Demon. How did I do it? Quite easily, actually. Bought a pair of 14" wheels from the auto wreckers with the small bolt pattern, and carefully cut the rim part off. I was able to buy a pair of "hoops" from a wheel manufacturer; which means outer rim with no centers. If you can't find those, just cut the centers out of a set of 15 X 8 wheels of any bolt circle. Anyway, in my case there was exactly 1/4" difference in the diameter of the wheel centers I planned to use, compared to the inside diameter of the "hoops". I welded 3/16" "pads on the part of the centers that contact the rim, then using the flange end of an old axle, I bolted my center to the flange of the axle, chucked it in a lathe and trued the "pads", turning the O.D. down to the exact inside diameter of the "hoops". In my case I wanted chrome wheels so I had the pieces chromed before I assembled them. If you are painting or powder coating you can skip that step. Anyway, I made up a little fixture using an old front flange/hub/spindle with the small bolt pattern, then bolted the center to it, carefully located my offset, put one tack on it to hold the location, and then with a dial indicator, trued the rim laterally, and radially, adding tacks as I went. When the wheel was running true, I welded the wheels securely and TADAA ! One complete pair of 15 X 8 reverse chrome wheels. Just about every guy in Toronto with a Dart, Demon, or Duster tried to buy those wheels from me. Lol. Anyway, I realize that not everyone is as determined (my wife says stubborn) as me, but if you want small B.C. 15 X 8 wheels of a particular style or offset and can't find them, there is your solution. Enjoy.
Thanks for the info...i had already thought of that, and is the way I will go...i like a challenge �� you have help me make up my mind.
Hey I don't know if this will help you, but this guy is pretty good at making up wheels in any configuration you want. I haven't bought anything form him but have met him at a few shows here in the area and seems like a nice guy. Give him a call if you can't find what you want. http://www.themopardude.com
Oh, and by the way my username on this site has nothing to do with this business.
66 dart 440 straight axel gasser 60s style
I was just curious. A 15x8 won't comfortably fit a 66 rear wheel house without offsetting springs at least. If you trim the wheel lip and offset the springs, it will work with a custom offset wheel. You need to talk to Stockton Wheel or Wheel Vintiques. Team III wheels has lots of gasser styled wheels. http://www.team3wheels.com/production_wheels.html
Don't forget to start a build thread and include lots of pictures. We like old gassers!
I had some small bolt wheels made at SheraDon Performance in Hugo, MN a few years back. 651-426-0061. $100 per for ralleye wheels.
Thanks for the help....sry about the pics...i will get some posted...have another question what back space do I want for for a stock rear spring set up for now...
Few years back someone was using a 15X8 hoop from donor wheels and welding 14 inch rally center pieces in. Sounds like a lot of work.
