goldduster318
Overzealous Car Modifier
Has anyone purchased the 70-72 Standard Grille reproduction from OER?
I see that they make the all black version above and one with a silver center and black surround only.
Given that I have a '70 Duster it needs to be black center and silver surround, which it doesn't appear that they make.
It seems my only choices are to fix my grille or another original '70 and re-paint, or to buy this center and paint the edges. I also don't know if the OER grilles have the slightly rough surface on the surround part to match how my original is.
My original grille has one large crack on the bottom, one of the upper outside trim screw areas is completely broken. Otherwise it's fixable with some hardware and probably some hours into it.
Thanks for any help!
