Anyone used the Ohio crankshaft stoker kit? Site shows 2K for the 360-340 ,internal balance,Thanks
o812 brian sells stroker kits also
I run an ohio crank stroker kit-noduar iron/int balance w/h beams and KB hypers=1300 shipped, I'm happy with it.
> Of course we know, oil throw-off, goes up to the "square" of bearing clearance increase ? Sounds like a LOT of oil on the walls ? Nascar motors run about .0005" ? ateam :read2:I'll add that K1's cranks are finished in the middle to low side allowing plenty of clearance with std. type bearing thickness. Alot of people get scared of .003 on the rods and mains and they don't like to see low (40 or less)idle pressure but truth is a real performance engine is MUCH happier and will live much longer with this clearance than say .002 on the rods and mains.
Some of our race engines use .004 on the mains and .0035 on the rods. It is application specific though so take that into consideration.
Brian
