Just to let you guys know, i have been talking with tekslk about this issue also. I have the intake that recently came off his engine and the plenum is overly oily. I went out tonight and inspected it and the gasket surfaces look very evenly compressed so i don't believe it's a fitment problem. I too came to the conclusion that the PCV was close to a rocker and picking up excess oil splash. If it is baffled properly then my only conclusion is too much crankcase pressure. It sounds ugly, but as some of you have brought up the rings, my next thought would be that the gaps are lined up or the 2nd ring could be upside down. The later would still allow a decent comp test, but will actually scrape oil toward the top ring......... I hope "T" by posting here i didn't offend you. I just found this thread and wanted everybody to know what i knew so we can come up with a solution for you. Afterall i love your Cuda :grin:.
