Oil cut off plug under rear main cap.
Dana456
New Member
Michigan
Have any of you guys knocked that plug out for before hot tanking, then reused the same plug with out issues…?
If you did reuse that plug, did you put any Loctite on it or just tap it back in dry?…
Thanks Marc
I always put some kinda sealant around those. I guess if it fits tight still, use it.......but the consequences of it coming loose....I'm not sure I'd chance it.
