The area circled in red is where you might be in trouble. If you are trying to emulate a distributor w/o vacuum advance then the numbers should be nearly the same top to bottom. The jump from 19 to 31 at 1500 rpm between 57 and 64 kPa is pretty substantial. You may not spend much time in that cell, but if you get close to it in-between the computer will extrapolate a number somewhere between 19 and 31.
If I were you, I'd try changing the timing in the 1500 , 1800, and 2100 rpm columns to be the same at all kPa values from 64 on down.
I found
a link to a nifty excel file that can help you calculate a table based on initial and total plus vacuum with a start/end kPa value.
As for actual timing values, I'll let others chime in on that.
