oil filters
If your leaking it has to be install,double seal?Warped filter adapter,
if used?
In my 30+ years the only filter I have ever had leak is a Wix. The crimp holding the can to the base was bad.
make sure the seal is on the old filter, heard of one sticking to the block and when the new filter was put on it leaked
leaking?? if you don't make sure when you install the filter you take some oil on your finger and run it around the rubber seal, that gives it a better seal. maybe you knew that but i've never heard of one leaking???
