Oil pan questions
Small Block Mopar Engine
  1. Richie
    Richie Well-Known Member
    884
    215
    May 27, 2005
    Kelowna BC Canada
    Local Time:
    12:34 AM
    Hi everybody:
    I was just wondering if it matters much if you have a baffled oil pan or not and are these after market ones as good as the factory ones. Some of them are pretty cheap price wise. I don't really want to take the pan off of the old 318 and use it for the 340 witch doesn't have one yet. Besides it looks like someone did the old put the jack under the engine bit at one time.
  2. Frnknsteen
    Frnknsteen FABO Gold Member FABO Gold Member
    547
    338
    May 26, 2011
    Spencer, IN
    Local Time:
    3:34 AM
    I look at it this way,... There was a reason that Chrysler put baffles and windage trays in their oil pans, at least on the more performance oriented engines. The baffles WILL help keep oil down in the sump of the pan for the pickup tube.
    I bought the "402" pan for my 440 from Mancini Racing because my original had the corners knocked in a bit and it would have been hard to knock out the dents under the baffles. Price was reasonable and it fit on with no issues. I had to mess with the length of the pickup tube, but that is quite common.
  3. nm9stheham
    nm9stheham Well-Known Member
    12,090
    3935
    Dec 20, 2013
    Waynesboro, VA
    Local Time:
    3:34 AM
    If you are just cruising and no serious racing, then the stock ones will be fine.
    • Agree Agree x 1
    • lilfontleroy
      lilfontleroy annoyinglilLeroy FABO Gold Member
      2,481
      2226
      Nov 20, 2017
      occupied
      Local Time:
      2:34 AM
      buy a new one! and spend the money on a good one with baffles it's worth it
    • brian6pac
      brian6pac Well-Known Member
      4,792
      3243
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      3:34 AM
      Someone said this and I don't remember who, but put a oil pan without baffles on the passenger seat floor put 4 qts of oil in it and have your ol lady hold it between her feet and drive around and try not to spill any on her shoes.
      • Like Like x 1
      • Agree Agree x 1
      • furrystump
        furrystump Well-Known Member
        1,072
        689
        Nov 13, 2004
        Local Time:
        8:34 AM
      • ScampMike
        ScampMike Despicable Damn Yankee
        34,057
        8896
        Oct 26, 2015
        all Mopar driveway
        Local Time:
        3:34 AM
        re-read your own post - you've already answered the question :thumbsup: - do not use the old pan and as stated in other posts, baffles are good.
        • Agree Agree x 1
        • Richie
          884
          215
          May 27, 2005
          Kelowna BC Canada
          Local Time:
          12:34 AM
          Well I'm a brilliant guy :lol:
          • Like Like x 2
          • AJ/FormS
            AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
            18,939
            6935
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            Local Time:
            2:34 AM
            If you're gonna spin that 340, then the oiling system needs all the help it can get. Get a hi-capacity one as deep as you dare, to get the oil away from the crank; foamy oil will take out your rod bearings in the blink of an eye.A skid-plate is a good idea.
          • TrailBeast
            TrailBeast AKA Mopars4us on Youtube
            21,408
            9007
            Mar 11, 2011
            Arizona
            Local Time:
            12:34 AM
            I have to agree on the baffled/windage tray vote since you want a new pan for it anyway.
            If you didn't need/want a new pan and you only ever drove the speed limit it wouldn't be necessary at all.
            And for that comment about your old lady holding a pan with oil in it between her feet, it would have to be 180-200 degree oil for that to be a fair experiment.
