shiifty_dart
can I remove the oil pan with the engine in the bay so I dont have to pull it or does it have to come out?
thanks shiifty
thanks shiifty
I agree, you will need a pickle fork and remove the center link from the streering gearbox and move it aside...break the driver's side tie rod connection with pickle fork...then you need a puller to remove the pitman arm from the steering gear boxDrop the centerlink, and pull it, take off the tranny shield first.
