My 273 build went pretty smooth and the pre-lube and initial start up went smooth also. As always with any big project there will be problems along the way. When I start my engine cold after setting overnight the engine fires immediately but it takes 10 seconds for the oil light to go out. (Long enough for a little rattle that doesn't sound like a lifter or rocker) I had the same problem before I rebuilt the engine. It's like the pump has to fill the filter up before the light goes out. I can only think of two things that are the same between the old and new engine.
1) One is I am using the same number of Car Quest premium oil filter. I am wondering if there is a filter that has a anti drainback valve in it to use with the factory right angle adapter.
2) Shame on me but I didn't replace the oil galley soft plug in the rear main bolt hole area. I remember checking it and tapping it to make sure it was tight but I didn't replace it. The block was pressure washed in a machine but not "cooked" or submersed in a hot caustic cooker. It also has a new pump and sender.
I need to do a little diagnosis like taking the filter off and see how much oil is inside before I start it. I need to hook a manual gauge up also but with the little knock just before the light goes out I'm sure there isn't much pressure. I got 65# when I pre-lubed it with a cordless drill but that was with all the asembly grease in there too. The oil clearances on the crank and rods were tight. Any suggestions? Anybody have a similar problem? Anything I'm overlooking? Mike
