NSdartSW
I got my 360 running fairly well minus the awful exhaust leak, I’m still trying to get tti headpipes for it, but I’ve ran into yet another problem. For a while off a cold start it would build like 35-40 psi and then drop down to like 20ish which I was ok with, it wasn’t the end of the world. But the last few times my gauge would just read 0 or practically there. I thought it was cause there was some air in line so I bleed it but with it completely off the gauge it was just a slow drip from the line. When it was running it wasn’t running bad or anything, it didn’t seem like it was running on no oil pressure. I tried to manually prime the oil system but no matter what I do nothing can get the oil pump shaft moving. I’m not sure what’s going on, maybe the pumps locked up or something? Looking for help from more experienced mind. Thank you
