moparstud440
For a 360 stroked to 408 that is a RACE only engine with no oil mods done using a solid flat tappet camshaft, 8 qt pan and RPMs stay under 6500 rpm which style oil pump do you guys like to use? Standard or High Volume?
My Mopar racer buddy has mostly used standard pumps. The hi vol use more hp
I have heard the same, Im thinking incorrect baffling for a particular situationWhen does it mandate a high capacity pan? Heard the rumors of 5qt pans getting sucked dry with the high volume pumps.
That is one poor excuse for proof ... when it shows clearly that the the RPM's were different. That said...If a high volume pump uses more hp, it's negligible (at best). Engine Masters just tested that theory.
...I'd say run whatever pump you want..because searching for hp in n oil pump is to be already be winning big money racing championships.
Lol Relax, it's not your testing, its enginemassas.Where did I say it was proof? I just posted that as an example. All three dyno curves were essentially identical - whatever that's worth. A number here or there really doesn't move the needle much.
I recently watched an Engine Master episode where they tested different oil pumps on engine on the dyno. It killed a few old wife's tails.For a 360 stroked to 408 that is a RACE only engine with no oil mods done using a solid flat tappet camshaft, 8 qt pan and RPMs stay under 6500 rpm which style oil pump do you guys like to use? Standard or High Volume?
I agree! Even if it did cost a few extra HP, the oil pump ain't the place to look for it. "OOO lemmie run a stock volume oil pump cause an HV pump takes too much power oooo"I recently watched an Engine Master episode where they tested different oil pumps on engine on the dyno. It killed a few old wife's tails.
Great info
My vote is for a Melling HV pump.
Not that there's anything wrong with that.How GAY does that sound?
LMAONot that there's anything wrong with that.![]()
Engine Masters actually shuts down the myth that it takes more HP to run an HV pump. Proved it on the dyno, no difference in HP standard pump vs HV.I agree! Even if it did cost a few extra HP, the oil pump ain't the place to look for it. "OOO lemmie run a stock volume oil pump cause an HV pump takes too much power oooo"
How GAY does that sound? lol
I run the stock factory 5 qt pan with a Melling HV pump.When does it mandate a high capacity pan? Heard the rumors of 5qt pans getting sucked dry with the high volume pumps.
Seinfeld reference. Big surprise.Not that there's anything wrong with that.![]()
Nailed it!Seinfeld reference. Big surprise.
Nailed it!![]()
