I add a few in the webbing between the lifters and cam tunnel to supplement the stuf the factory does. I also beldn them so there is no low area to hold oil. I want all the oil I can to hit the cam, as I said, my concern is life at idle on the street for the cam, not so much windage control. Also, the cam is splash oiled from the bottom, not the top. So you can stop the oil from dripping down onto the cam all you want. You want the oil to splash up off the crank and hit the cam from the bottom. That's why MP didnt sweat the holes. They let them go for maximum strength. You could also use the EDM lifters and completely surround the cam if you wanted. But it's a lot of work. I'd estimate 70% of the loss from windage is controlled by a tray and scraper or just scraper. The other 30% is a small figure for the effort and possible risk IMO. Were talking 0-30hp at best on a 500hp engine. You'll lose more than that on a hot day due to weather. Mal, the scraper pulls oil off the crank that "could" be splashed on the cam. So it could be an issue on a fast rate solid with a high spring load, or a roller where it just wears out the lifters faster. Or it might not be an issue at all... The big power producer is a dry sump. If it's a race car, dry sump will free up a lot more power, but is expensive and hard to package.
