Oil stain
Snake
Mopar Nut
Belleville Canada
What can I use to remove oil my my asphalt driveway, pulled the engine out yesterday and well you know the rest of the story. I am very pissed at my self,I am a nut when it come to NO OIL ON THE DRIVEWAY :banghead: your car leak oil don't park it here.Any thoughts.
Dish soap. You haven't had enough heat to make the asphalt soft. Pressure wash and then seal your driveway to protect against future spills.
pine sol! let it work pressure wash, great for cleanig carb too and it smell good!
worked good for removing atf fluids on my driveway !
gasoline will break down the asphalt do not do that. Just take a cup of tide laundry soap and a little water and no more oil
I always use oil dry (kitty litter). I just grind it into the stain with a twisting motion of my foot and let it sit for a couple of days and then sweep it away. I don't like stains in my driveway either.
X2 works for bird poop also
Yeah, oil dry/kitty litter as said above. Trick is to get to it right away. Only I let it set and soak up some before grinding it in.
