Actually happens every crank rotation or twice per cam rotation.the rockers get timed oil pressure, that means the camshaft oil port must line up with the rocker shaft passage, and that happens once every 2 crank rotations, or 1 camshaft rotation assuming you did not replace the cam bearings and not clock 'em correctly.
