Old Electronic Ignition Instructions
John Wymore
Active Member
Scottsdale, AZ
Bought a NOS points distributor off eBay a while back and the guy sent it in an old box with some original electronic ignition instructions and a couple old stickers. Pretty cool .... hopefully you guys can open up the PDF.
  • Mopar Electronic Ignition Instruction.pdf
Interesting because that which you posted is about the best written destructions I've seen. Complete with some troubleshooting hints............They go into detail about the IGN2 wiring WHICH IS WHY I am always "bitchin" about this incorrect diagram that shows the "start" wire with no explanation, and so far as that goes, is incorrect
BELOW IS INCORRECT (yellow start wire)
ABOVE IS INCORRECT
Maybe a corrected version would be a good thing to spread around.
Thanks
@halifaxhops
Thanks for scanning and sharing this.
"Mighty Mopar Chrysler Performance Parts" might be mid-1970s to early 1980s.
Distributors P3690426 through P3690428 are the p-part distributors with vacuum advance that continued to be sold through the Mopar Performance era.
P3690422 - 5 may be cast iron housing race units with tach drive. Not that its important but just a matter of curiosity. The cast iron ones in the early 80s are a P4286510... and in 1983 the aluminum housing versions were offered...
Interesting that the instructions are for an ECU that requires a "dual resistor" set up.
Was wondering about that also. Maybe for a chrome box that takes a ,25 ohm one. Also solid core wire must be used. Also 20 amp switch? Most ecu's I have tested take 5 A max not running. Would like to know what box that was. Gold maybe?
@krazykuda look in that early MP book I sent you
Those stickers are cool! I bet they are from before the "direct connection" name was in use. So maybe early '70s. I've got a 1977 Direct Connection catalog, I'll look and see if they're in there.
See what High end ecu part numbers the gold and early chrome units. I sent Karl all my catalouges, he has a place for them they would get destroyed in my shop.
Thanks, the plot thickens. That ballast 2095501 is .5 ohm hot. Still not getting a 20 amp switch for the ignition. Overkill to be safe?
Wow, this generated a lot of conversation!! Wish I could provide more input on dates but this all came with a different (points) distributer and no ECU so I have no idea. BTW, if anyone is interested, The box it all came in was from Royal Dodge, 15095 S. Gordon, Alvin, TX, 77511.
ABOVE IS INCORRECT
You sure are! Why don't you do something positive, like go eat some chinkese? LOL
