Orange Twists 71 Duster Build
I cant believe how well that underbody came out for an on the back job......
You my friend, And your pops deserve a huge congrats and a few beers !!!!
You are an inspiration to me and my project dude, seriously. You work at the level I want to be at! After reading through this, I am considering stripping my whole car down and doing it the right way!
I would really love to see you put up more pictures of the whole process!
Thanks man, I really appreciate it.
Thanks. Im definitely happy with they way it came out. Dads done a few of his cars that way and they always come out great. It just sucks, now i gotta clean the bottom more than normal. :D
love it very nice
thanks man. i imagine we will run into each other eventually at a show somewhere. Indiana isnt all that big.
Alright guys...I havent posted anything for a while. Had a lot going on the past month, had some big changes. but its all starting to work out and for the better at that. enough of that, heres where im at...
car is pretty much done, i just have little things to finish up...seatbelts, shifter boot and trim ring, hook up lights, horn, and touch up a few spots on the underside from installing the tranny cross member.
I managed to make it in time to get my registration sent in to world of wheels, just waiting on the reply. from what ive been told i should know by next week sometime. I guess they had a lot of registrations come in at once, and have not had a chance to review them yet.
pics coming in a few...i forgot to upload them :oops:
Finally got around to finishing up the grill
Didnt come out too bad...im kind of picky, so it may end up getting redone next year. i havent decided yet.
Also go the headliner in. i cant take credit for installing it. i want to try one, just not on something where it has to be 100% perfect.
slapped some interior in it
rolled her outside to sweep out the garage. its filthy in these but you get the idea...
put the grill in, and cleaned it up a little bit. still needs detailed and waxed...
WOW thats NICE!!!
Who's stripe kit did you use?
thanks
i used phoenix. but i guess nobody makes a "twister" decal in the matte black. so i ended up with 340 decals, twister in gloss black, and another set of twister that i didnt like. i ended up taking the gloss black twister decals to a local sign company and having them make me a set of twister decals in the matte black. they only charged me like 12 bucks for 3 decals (i got an extra to make sure i like them before putting them on the car)
i love the old cal customs valve covers. just refinished the set ove had since middle school for mine.
yours dont look like polished aluminum, though. may be the camera or my screen.
just what are they finished with?
alsom im running made4you vertical plug wire looms with mine. really makes it a much nicer and cleaner install.
They are coated in chrome powder. No need to bother polishing them all the time anymore and look pretty good.
Got any pics of the looms you're talking about? I like making things look cleaner.
** found the looms. Think ill order some tomorrow.**
wondering what sound deadener did you use? Also, i am EXTREMELY interested on how you repaired the grill...what paints and material did you use to fix the cracks in the plastic and lenses? I'm about to start doing my sharktooth! Car looks WONDERFUL great job!
The sound deadener was from ebay. Basically the same as fatmat. Used it before its pretty good stuff.
For the grill I ordered a plastex kit from the net. Pretty good stuff. Easy to use, but I suggest experimenting with it some to get a feel for it. For paint I used mopar rallye wheel paint for the silver, krylon satin black, and krylon satin clear.
great thanks so much for the info i'll be following in your footsteps it really looks great! Do you know of the sound deadener brand like milla mat or raam mat or something? That dynamat is really expensive unfortunately:(
ill bite on this, even though i wasnt asked. im also copying and pastiong from a post i did on moparts, as i REALLY dont feel like re-typing it all. it took me long enough the first time.
having done this kind of thing to a bunch of cars, ill give a few tips.
1. don't buy name brand dynamat. its ridiculously overpriced for what it is. i use http://www.mcmaster.com/#catalog/117/3497/=fqjmp1 the plastic 10% sheets. works very well. use a heat gun and J roller to work it in tight to the sheet metal. prep the surface, even if freshly painted, with a pre-painting prep. you want it as clean as if you were about to lay down a top coat of 100 a gallon paint.
2. you only need to do about 80% of the interior. the last 20% really doesn't get you any noticeable results. i use the thump method. if i hear a tinny sound, a vibration, an oil canning, etc,. anything other than a dull thud, it needs it. if,m like on the roof of my truck, theres a gap between a brace or other piece of sheet metal and the panel, work the sheet onto the gap. wit will eliminate the rattle.
3. use the stuff to cover over holes in inner structure. after you get the outer surface of the door done, do the inner structure in its entirety. you'd be SHOCKED at the sound reduction. same in the rear quarter and sail panel openings.
4. do the stuff under other bolt on parts. even when things are fastened sown tight, they still vibrate and rattle going down the road due to chassis flex.
5. cover it over with something like what has already been discussed. i prefer to put the foil side down, and glue it. adding mass to the large stamped panels in our cars really helps. do this in all the areas you can. especially the roof, firewall, floor, and trunk divider.
6. i also tend to use a third layer of insulation. i use the foil bubble wrap they sell at Lowe's as a final layer over everything. did this in my half ton, and it created amazing results with the heat and AC functioning.
i have only ever had one issue with doing this kind of stuff, and thats on a 79 corvette that i just finished. the carpets for those cars is notorious for being ill fitting (due to the production tolerances on the cars, and the various mid year changes, etc). still easily workable. just a little less defined and form fitting than i prefer. but i honestly think that was the carpets fault. on that car, due to the carpets, i only did the "dynamat" and the bubble wrap. not enough room for anything else.
a good way to estimate how much material you need is to take a tape measure and measure the various big areas of the car, rounding UP to the nearest foot. so say that you have a trunk 54X61 inches. thats 20 square feet rounded up. (5ftX6ft) reason you round up is to account for contours, mis cuts, etc. you'll wind up with some left over, but its a lot better than running out.
lastly, look at your carpet choice. stockinteriors.com has what they call the mass backing option. this is similar to what GM started doing in the 80's on their carpets. its about 1/8 inch of rubber bonded to the backs of the carpets. amazing sound reduction there as well.
hope i gave you some solutions. not all that expensive when you add it up, but labor intensive. worth every minute, though. my duster has 400HP at the wheels, with 3 inch exhaust. its as quiet as my wifes stock 2002 Subaru legacy GT wagon on the inside at 65. except for the wind noise from my windows. (still working on that solution)
Michael
Thanks for replying to that dusterbd I meant to say the same thing after I saw he asked but I forgot until Igot the notification you commented.
By they way. Thanks for the tip on the made4you looms, I should have some tomorrow.
they are slick. ilove em. hopefully ill finish my valve cover job this weekend and post pics in my build thread. job, weather, family, etc have not allowed me to get it done.
beautiful job on youjr car!! Who makes the front air dam ( spoiler)? I really likw it!
Thanks. The front spoiler is from Spoilers by Randy. Fit perfect right out of the box, comes matte black already.
I know what you mean there. Hopefully ill get mine on this weekend too.
any chance you will post pics of the madeforyou looms and a link?
car is outsatnding for sure
Mark
I've been looking for a twister set. Looks like im gonna have to do the same. I have a NOS Twister deacal in White but I also need a Matte black one. Ill keep this in mind. Thanks
thanks
Mark
Sure will, mark. I thought id have them today, but I guess they didn't ship in time yesterday, so I will have them tomorrow. Hopefully install them on Saturday and I will get some pics up Saturday or Sunday.
