Moparply
Original 1970 Duster Dart 340 bell housing, part number 2892482, early 2 - 70 dated, $100
I just cleaned/degreased and inspected the bell housing. It will need some repairs. There is a small crack about 1 1/2" long, there are 2 pictures of this area, it's in an open area and is easy to get to. You can see what caused this by the small mark on the outside surface in the blue paint area.
There is one repaired threads with a helicoil. One of the starter bolt hoes has some threads partially missing, that hole should probably get a helicoil.
Located in NJ
Nationals delivery with prior arrangements.
Located in NJ
