mopar56
Ok so my sons 70 Duster we resurrected last year has been running well since we got her on the road last June, during the resurrection process we performed the " Mad " bypass, we have done this procedure on his last Duster to, however instead of using fuseable links we used marine 10 gauge ato fuse holders with a 40 amp fuse in one and I think a 25 amp in the other, we only used different fuse sizes because the procedure called for different gauge fuesable links, any way just lately the alternator stopped charging which we diagnosed to a blown 40a fuse we replaced it and all was good, we checked the voltage at the battery and watched the voltage increase but instead of leveling out at 14.2 it kept climbing and finally blew the fuse again, we checked for grounded hot wire but could see nothing. I suspected a bad voltage regulator so replaced it with what I believe is a good used one I had in my parts cabinet but got the same result, it charges at idle but as you increase rpms the voltage increases at the battery on the meter and somewhere between 14.7 -15 v it blows the fuse, any ideas? BTW the alternator was professionally rebuilt last June to and has very little mileage as the car is stored in the winter.
