overhaul help
blasterboy
Active Member
awhile back i asked in this thread about a manual or instruction sheet on overhaul of 833. surfing through the web hit on the help. go to autozone site and work your way around to transmission it is listed for dodge truck but it is for a od 833 print off sheets it is a very good and free . you can also lookup and down load info on parts and numbers for your application. :wav:
