painting interior trim
iggys68dart
jacksonville fla
im going to paint some a pillar trim that is tan and i want to go red/maroon color any tips i should know thanks
Rustoleum has a line of vinyl and trim paints out now, I'm pretty happy with how my parts turned out. Available at the local Autozone/Advance/wherever.
IF you plan to paint all the interior to match, you can wet sand those A-pillar pieces and paint them with the same enamel used on the metal pieces. Just be sure to bend your paper into their grooves. Knock all the gloss off of them. The flexible dyes for vinyl and plastics are great for those pieces that will be flexed.
The A=pillar trims are abs plastic and just like the instrument panel. They dont bend much before breaking.
