You have a stock wiring harness?
Might be a problem right in the turn signal switch
.....problem in the hazard flasher switch, turn signal switch or wiring.
I'm going to guess, By "park lights" you are really seeing the brighter turn element in those front 1157 bulbs and by "dash lights" you mean the turn indicators and not dash illumination.
Probably a problem in the hazard flasher switch, turn signal switch or wiring. Do these switches do what they should ?
The actual dash lights illuminate.
