Part numbers for 7.25 rear end parts
autumn ash
Texas
7.25, 10 inch drums, out of 65 barracuda. I need the part numbers for: axle oils seals, pinion oil seal, and right handed wheel studs. - thank you
The original part numbers may have been superceded, and there are aftermarket seals and studs available too, but, the original Mopar axle seal number is 2404052, The pinion seal is 2404134. 2070158 is the RH wheel stud.
Here's the history of the Chrysler 7 1/4 pinion seal part number. For those of you familiar with the Chrysler parts catalog, its found under 3-22-45.
1960 thru 1965 part number - 2070113
1966 thru 1968 part number - 2404134
In 1969 Chrysler superseded 2404134 back to 2070113
It may seem strange but sometimes Chrysler would supersede a newer number back to a older one.
All those part numbers cross over to National and Timken number 8516N
