[SOLD] Parting out My 65 Barracuda
What color are they
The are more of a dark brown rather than the goldish color of the interior and dash. I figured they would go well with the interior gold color and one of the gold dash pads I have (the Plymouth pad is more gold than the Dart pad)
I would like to buy the altenater brackets every thing to install could you give me a price if still for sale
steering column bracket to firewall?
Thanks, dave
I think you are referring to the complete bracket assembly with the brake and clutch pedals? Or the bracket that holds the steering column to the dash?
Just the plate support for column going thru firewall to gearbox.
However, this 65 dart was 3 on tree changing to 4spd.floor.
sold 3 on tree column assy. Wondering if plate is different for auto/manual floor columns? The column I have now plate lot smaller,wont fit.
Guess I can modify.
Thanks Dave
Ah OK! The floor plate which for the 65 comes in 2 pieces. The smaller plate is the first piece installed to the steering column tube. After the column is assembled and fitted to the steering box, the smaller plate is bolted to the larger plate already bolted to the floor. Here’s the one from the Barracuda (still in the car)
Here is the set I will be using in my wago
I have a loose auto larger floor plate (no cut-out for the clutch rod) and a loose small plate from some other early A which could be cut to match the 65 smaller plate.
Exactly! Ive got small plate. Let me try to find, hopefully, the large plate is MIA.
Thanks, Dave
Do you have the four pieces of dash trim? Price shipped to 39073?
Thanks
