mpd12150
I have a Paxton supercharger that I will not be using on my current project as I am going with spray. Rather then let is sit on the shelf in the shop and not use it, I am going to put it out for sale and see what happens.
This unit is a the Paxton Novi 2000 and is approximately 6 years old. Included is the sale is the supercharger itself, pulleys, blow through hat, belt, tentioner, mounting braket, wiring and various plumbing to install on a magnum engine, it is easily installed on an LA engine by changing the mounting bracket.
This unit depending on pulley will run anywhere from 8 to 27 pounds of boost. It is not a self View attachment 1714955619 oiling unit so you will need to tap a feed and return line.
The unit is in great condition and will create reliable power that is easily tuneable for a very reasonable price.
$2750 get in touch and lets work out a deal.
