Purple Haze
If that is the case than there should be a separate filter for it, the factory system is know as a closed pcv system. You can run a pcv valve and a breather type cap ( the kind that has holes in the bottom and mesh inside ) that is know as an open pcv system. Sounds like you have a GM style air filter which has the breather connected to the air filter but uses a separate mesh filter because it is before the carb air filter element.
