quick question:
Has anyone had issues hooking up a pcv to one of the 3/8 ports off the back of a FI Tech throttle body (30003)?
I found off google- of all places posts from a few years ago with the same issues on here but when I tried to search them directly it went no where. The post off google from here talked about splitting the vacuums from both 3/8” ports since one feeds the left bank and the other feeds the right bank. But no conclusion on what was correct or if both were needed.
Any ideas? There is a vacuum divider break under the throttle body - small but a divider. Just would hate to run a “tee” off both to equalize the possible vacuum. If that was the case then I had better run it off the O2 sensor side.
Let me know your thoughts.
Joe
Joe
