AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,933
- Reaction score
- 12,283
You have a rock-hard pedal with the engine off.I have never seen it where a rock-hard pedal had hydraulic problems. A Rock-hard pedal means your foot is directly linked to the wheels.
And you say fresh fluid is coming from every port.That means at near zero pressure, there are no restrictions in the lines and hoses.
And you say the rear brakes are properly adjusted.
And the front pads are nearly new.
And you can hear the brake parts working at the wheels.
And there are no external leaks.
And the pedal drops with a toe on it, when the vehicle starts up.
But you say the problem does not show,until the vehicle is started, and it did it before the booster was changed.
Let's assume that you know what you are doing, and that everything you have said is true.
Did this truck come home with you from vacation? Does it have ABS? Does it have a rear, bed-mounted proportioning valve?
If no,no, and no; then I believe that there are just two possible issues left. The booster or a demon.
The least likely, is the booster,cuz it behaves correctly, perhaps too much so. That leads to a pushrod adjustment.
But the most likely, is that something mechanical is fooling your hydraulics.Somewhere, something is acting as an accumulator. I believe it will be in the rear system. When I come to this point, I like to isolate the front from the rear, and work on just one end atta time.But before that, I think it would be a good idea to check the park-brake system. If it were to be on or partly on, during the rear shoe adjustment, it could easily mislead you into thinking everything was A-OK back there.
