Hey guys, got a 73 swinger with a 318 with a weiand stealth, 600 edelbrock, comp XE256H, 2.25 in exhaust from the manifolds back and timed 10* BTDC. This summer I am looking to swap out my heads for edelbrock performer rpm heads and maybe switch my weiand for a performer rpm manifold. Anyone have an opinion on performer rpm cam vs. a comp cam XE268H or this setup? Its a three speed automatic with the stock stall and 2.73 rear end.
You know,, because your engine is still together, and running, and by your description should be very strong, except you're beating your head against the wall because of your gear and exhaust limitations..
I humbly suggest that instead of spending over a grand$ on heads, cam, etc.,, you give the engine you have, which should be very stout, a chance to show it's stuff..
Headers and Gears are the most cost effective mods you can make,, so to keep trying to make more H/P while shackling/choking the engine, just doesn't make sense, imho..
Spend the $$$ on gears and exhaust,, you will see/feel/have more usable H/P
that you already have...
Then if you want more power,, you'll have the platform to USE more power, and you will actually feel the improvement to it's full value.. jmo
hope it helps
