Treblig
More tedious reading for those who are barely awake!!
Mopar Chrysler Engine Specifications - MyMopar.com
I was too sleepy to do the math myself, I figured that some coffee guzzling, math whiz on FABO would "jump in". If you do a little research I'm sure you'll find the same chart that I saw, it shows that 67/68/69 factory engines all have the same compression....9.2:1. Maybe the difference was so slight the factory didn't care??? I know that the factory head CCs varied quite a bit.
But they did mess with the pin height a bit too.I was too sleepy to do the math myself, I figured that some coffee guzzling, math whiz on FABO would "jump in". If you do a little research I'm sure you'll find the same chart that I saw, it shows that 67/68/69 factory engines all have the same compression....9.2:1. Maybe the difference was so slight the factory didn't care??? I know that the factory head CCs varied quite a bit.
I think that you are right that there is slight difference in compression for those years, chrysler didn't bother to update the info....
