picked up a blow through carb.
brandon2701
brandon2701
HAWAII
It's an edelbrock though and i'm not sure if the guy knew what he was doing so I am here to ask the teachers. How can i be sure if its a blow-through without cracking into it? and can you make a blow through and edelbrock 650 cfm carb?
I was reading that some blower Avanti's(??) had blow-through AFB's from the factory. Unless I was dreaming. I think it can be done but it's not as easy as a Holley
You can Blow Through a Edelbrock.
It has been done.
The main issue with AFB's is the Brass Floats are Hollow...and can be crushed by the Boost Pressure.
A guy over on theturboforums has used a Edelbrock in Blow Through Config to much luck I guess.
Here is the link....http://www.theturboforums.com/smf/index.php?topic=136075.0
From reading his thread....You need to seal the accelerator pump shaft with a rubber washer on the under side of the top plate...and cross your fingers....and I am not an accountant or anything but a rubber washer is cheaper than a Custom Setup Holley carb.
Good Luck.
