Reddartowner
UCF Alumni....Go Knights!
Hi...
Working on setting up a build for a 383 to go in my son's Dart. The basic setup will be like this:
9.5 to 10:1 compression
Comp Cams XE262H (building this motor for torque, not all-out HP)
Stock Crank
Reworked stock rods
Approx. 75cc heads to get compression with flat top pistons.
What pistons/rings would you recommend for this sort of build.? So far I've looked at Speed Pro and Diamond pistons. Any particular brand of rings that stand out..?? Any other pistons to consider.?
Thanks....
Stock Crank
Reworked stock rods
Thanks....
