pitman and idler arm bushing, where to buy?
LS1 ACE
Good evening,
I've got a 69 Valiant with a 73' spool type k-member. All the bushings in it are good minus the pitman and idler arm bushings. The arms themselves are in good shape and I do not need them. However, I haven't been able to find just the bushings. I tried a search and didn't come up with anything. I called pst but they only offer the arms AND bushings together. Anyone know where I can get the bushings by themselves? Any links or information would be appreciated. Would like to get the front end completed before dropping in the motor. Thanks.
If you look under applications...click on dodge...and the darts are listed.
I have always just replaced the entire pitman arm or idler arm...
What bushings are in a pitman arm? Do yourself a favor and get a new idler and pitman if they're too worn to use. Trying to replace the bushings in an idler arm isn't worth the trouble.
