pitman arm?
03ramit1
Glendale Az
I have a 75 duster, and i picked up a used gear box, to convert it to manual steer, and the power pitman arm does not work. (wont hold tight as the shaft on the gearbox is too small for the pitman arm) anyone know a part number to get the one I need? thanks a bunch.
In 1973 the diameter of the shaft on the steering boxes changed....your 75 duster has the larger diameter pitman arm..where as the new steering box you got has the smaller diameter splines....
I can't remember what the box came out of. But I know it was a 60 something. I wanna say valliant, but I could be wrong. I'll have to grab the moog arm listed above and give it a shot. Thanks for all the help guys. This place rocks.
